Could Invisalign with IPR or elastics reduce protrusion?
Jjosephine94
#1 Post by Jjosephine94 »
I just got braces off to close open bite with palate expander and elastics. However I am not happy with how protruded and slanted my teeth look. Could Invisalign with IPR or elastics help reduce protrusion?
jem
Re: Could Invisalign with IPR or elastics reduce protrusion?
#3 Post by jem »
I think your teeth look lovely. I don't see any obvious protrusion. Can you close your lips fully?
If you are unhappy with your treatment outcome, I suggest you discuss with your orthodontist.
What sort of retainers do you have? Perhaps some IPR in combination with slightly activated hawleys might push your teeth a little further inwards?
Jem
djspeece
#4 Post by djspeece »
I would agree with Jem. especially with his recommendation for discussing the issue with your ortho. It looks as though your front teeth are angled outwards a bit, which may be necessary in your case to ensure a functional bite. But in any event, your teeth look very good to me, and I wish you the best of luck to achieve complete happiness with the ultimate result.
