![Sad :(](./images/smilies/icon_sad.gif)
I have Damon 3 braces on my bottom teeth. Since I got them a few weeks ago, every now and then while eating, the wire would get bent outwards from the second-to-last bracket. I don't understand why there isn't something holding the wire in on this bracket like on all the others (they all look the same except the very last brackets on each side). I dealt with it by just pushing the wire back and then it would snap back into place. Is this even normal?
Today, though, I was eating and the wire came all the way out of the end of the last bracket on the right. This is a different-looking bracket with no ceramic. This time I "fixed" it by sliding the wire underneath the last bracket. While typing this, I accidentally took it out again with my tongue, so this can't be right..
Of course, I don't really know what I'm doing, and I'm quite confused. Are things supposed to be this loose on the last 2 brackets on just one side of my mouth? Or is something broken? Any ideas...thanks!
