wire ties vs. ligs
wire ties vs. ligs
i just had an adjustment today. My teeth hurt real bad. But anyways I have one wire tie on one tooth and the other four have ligs. The ortho put a lig for the first time on my impacted tooth that just came down and boy did that hurt. The assistant was having such a hard time. Does anyone know why this would be? What is the diff.? I've never had a wire tie before.
-Hannah
-Hannah
wow!! you only have 1 wire tie!! *is thinking how lucky hanna164 is* i have four wire ties, because i have rotated canines, means they are turned in ward creating a "corner" in my arch instead of rounded, but that is quickly going away, they are becoming quite straight, and i have only had braces a week!!! but my wire ties are to keep the arch wire from warping and popping the bracket off when the tooth starts to rotate back into place. Hope this helps!!
O.o*Shelby*o.O
braced on:9-29-05
http://tickers.TickerFactory.com/ezt/d/ ... /event.png[/img]
braced on:9-29-05
Thanks for all your replies guys! I've never had wire ties before but they hurt so bad. I can hardly bite down its so painful. I haven't really eaten all day. Sorry for you guys who have wire ties on all your teeth. That must hurt. JI don't know what they're trying to do using them but I hope it works!
-Hannah
-Hannah
I have all wire ties and have no problems..my ortho said its up to me if I want ligs or wire ties..wire ties just take longer to put on..
crowding, mild overjet, and crossbite
SARPE AND R.P Expander: 7-14-05
extraction : 9-15-05
Brace date: 9-29-05
Expander out! 1-12-06!!!!! after 6 long mos.
Taking them off!!! Feb 26, 2007
http://www.archwired.com/phpbb2/viewtopic.php?t=5209
Brace date: 9-29-05
