Help!!! Lower Expander just came out!!!
wating4braces
#1 Post by wating4braces »
Help!!!!! My expander just popped out!! ok... well it didnt exaclty pop out by itself. it has been loose for a few days but i thought it was ok and i was playing w/ it a little rougher than usual and it came completely off on one side!! a week or two ago the part that holds the wire to the band (the band attatched to my lower expander) came off on one side. i think the only thing holding it in on the other side is the archwire. :? help!
*Marta*
#2 Post by *Marta* »
Well... If I were you, I... I would just call the ortho's office. They'll either tell you not to worry because it's nothing serious, or (more probably) make an extra appointment for you. Anyway, calling your ortho will surely make you less nervous :-) Don't worry, such things happen.
99 weeks in braces (4 Dec 2003 - 27 Oct 2005)
wating4braces
#3 Post by wating4braces »
Thanks! Its all taken care of now though. ITs gonna be weird not being able to click it back and forth.
jaws
#4 Post by jaws »
I actually just had this happen to me a couple of days ago. My lower expander popped out on one side, but remained attached on the other side. I called my ortho and they got me in the first thing the next morning. However, my ortho is on holidays, so the assistant put the expander back in it's place--and now my teeth are hurting like crazy! Who knows what she did! :?
Braces are Now Off!
Metal Braces Top and Bottom
Expanders Top and Bottom
April 11th 2005-June 27th 2006
