Congrats to you both on your new teeth! Your journey is just beginning & I hope it's a good one for you! How are you both doing today with them? Update us ok?
Spacers-9-19-05
Top Braced-10-03-05
lowers on-10-17-05
appliance installed in mouth 10-17-05
2 extractions on 8-3-06
2 years treatment time
Better today, last night I wanted to cry my teeth hurt so bad. I had only liquids and some mashed potatoes until supper, then I actually ate some semi-solid food. I don't regret getting braces though, I know it will be worth it in the end.
BJ23 How are you doing with your braces? Are you able to eat okay?
upper metal braces applied November 8th, 2005
lower metal braces applied February 23rd, 2006
Believe it or not, I have had no pain yet! I thought I would be a soldier and attempt to eat some Tyson chicken fingers. They are soft, but as soon as I bit down, I had the shock of a lifetime. So going forward, no more SOLID FOODS for me...lol
I am sticking to Ramen noodles, mashed potatoes, meatloaf, soup, etc...
Other than that, my teeth don't hurt a bit. I will be having 4 extractions done once my ortho feels some allignment has taken place with my teeth/bite. Then, I will probably feel the pain that you all have felt...
Got bottoms braced the morning of 8th, and am not having the best of times right now I have a sore on the side of my tongue from the cleat on the band and the outer portion of the band is digging into my cheek!! I am going through a stick of wax each time I put it on (for all of my mouth) and I have a pretty high tolerance for pain.
Ceramic Uppers 9/6/05; metal lowers 11/8/05
4 bicuspids removed 10/26/05
33 y.o. male whose parents couldn't afford braces as a teen---and YES, I TOO AM OBSESSED!!
Jodster, did they pinch the cleat with a pair of pliers to make it as minimal as possible? I read that they sometimes forget to do that, and that's just what they did when I had my lowers put on. So I asked and was very glad I did. If the assistant didn't do this for you then it could be fixed-up pretty quickly and save your tounge.
Music in the soul can be heard by the universe
Upper ceramics: 3 Oct 2005, Lower metals: 1 Nov 2005
Braces remove: April 4, 2007!
Geri wrote:Jodster, did they pinch the cleat with a pair of pliers to make it as minimal as possible? I read that they sometimes forget to do that, and that's just what they did when I had my lowers put on. So I asked and was very glad I did. If the assistant didn't do this for you then it could be fixed-up pretty quickly and save your tounge.
Not that I am aware of. The cleat on the other side is still obtrusive, but doesn't bother me near as much. I went in right after that last post to have them grind it down. The Ortho was quite surpised that I had developed as large of a sore as I did...OH WELL. Hopefully I will see progress in the next week in terms of healing.
