Upper or Lower brace only?
Anyone here has gotten either an upper or lower brace only?
I've got the upper alone.... Is this common?
My lower front teeth are so over-erupted the top teeth completely cover them when I bite. It's been 5 months so far on top and the ortho says next appointment there will be enough space for the lowers to go on. I think he's crazy because there is ZERO room but I'll wait until I actually don't see them fit to start freaking out... I think I'm screwed though.
My daughter has uppers only. She got her uppers in September and will get her lowers on in April. I can think of two reasons why this will happen. 1) there is a deep bite and they want to avoid having the uppers bite off the lower bracket. Although there is a bite plate solution to this 2) The lowers needs a shorter treatment time so why bracket them earlier?
I had the uppers put on. Then 14 days later I had the bottom put on.
My othro asked if I had time and to have the bottom put on, so this was an option and I took it. Did not want to wait for the next appointment to have the bottom put on. Which was in 4 weeks.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10724;107/st/20060110/e/braced/dt/-2/k/606b/event.png)
In process...
4 spacer and upper braced 1/10
Spacer removed and fully braced 1/24
Final 05/15/08
Uppers/lowers
I had my uppers on Feb 18 my lowers go on March 7. My doc prefers to do it this way with everyone to let them adjust. Good thing for me. My tech put a square thicker archwire on me and after having the braces on for 7 days I had to have it changed to the round thinner archwire put on. I couldn't bite into anything even toast. Could you imagine if I have both put on at one time. Thanks doc.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10715;107/st/20060118/e/Upper+braces+Placed/dt/-1/k/368b/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10719;119/st/20060214/e/Lower+braces+Placed/dt/-1/k/30b2/event.png)
I see. I have a medical condition involving my joints and so on, so my dentist was scared about doing too much unnecessary work. This is why we opted for just a top brace, since I'm okie with my bottom teeth as they are more or less.Flora2006 wrote:I have my top ones only as well. It will be a while before I get the bottom ones because my bottom teeth aren't bad at all.
I'm beginning to wonder if maybe later on I should get a lower brace...just to complete the whole experience. I have to see what the price factor is like too.
