Biggest OVERBITE/OVERJET Ever
All this talk about overbites and overjets prompted me to call my ortho.
I inquired about the size in millimeters and percentages of my overbite and which of them I actually had.
Their response, both!
Overjet: 10mm
Overbite: 100%
Holy Cow!! Guess I've got a long way to go
Overjet: 10mm
Overbite: 100%
Braced: 9/23/05
Having 4 wisdom teeth extracted: 2/17/06 *ouchie*
Ceramic on top, metal below.
Duration: 2 years
Duration: 2 years
Yep Flora, its a LOT of protruding.Flora2006 wrote:I don't even know what those are My dentist and ortho never mentioned anything like that to me...no overjet, underbite, overbite, etc...just one crossbite.
Is that a lot? As in 10mm protruding to the front or something?
Funny thing is that most people dont realize that I have an overbite, which is weird beceause I can definitely see it.
Braced: 9/23/05
Duration: 2 years
Duration: 2 years
Hey Chris,momof2grlz wrote:I'm right there with ya. 10 mm overjet and "almost" 100% overbite. I'm sure there's others out there with larger overjet. That's a record I don't really want to hold!
Chris
Guess I'm not alone. I agree, definitely not a title I like holding. Hopefully these braces do what they are supposed to - and quickly too!!
Braced: 9/23/05
Duration: 2 years
Duration: 2 years
I look forward to seeing your pics darkangel.Dark_angel wrote:I come very close to you with a 9mm overject although im sure it has probably been reduced a little and im not sure about my overbite, its not that bad. I'll try and post some pics later.
I'm going to try to keep a running log so that I can track the progress.
Do you guys do the same?
Braced: 9/23/05
Duration: 2 years
Duration: 2 years
I guess I have the record here!!! I started out with an 11mm overjet but the last time the orthodontist measured it was down to just 4mm !!!:jump:
Braced on: June 28, 2004
Debanding : June 16th 2006
To be one, to be united is a great thing. But to respect the right to be different is maybe even greater.
Bono
Bono
I was wondering how your orthodontist is reducing/correcting your overjet? I have an overjet and will be getting braces in a few months to reduce the overjet.
I have a crossbite which is currently being corrected with an expander.
Thanks.
ssfw
Thanks.
ssfw
Braces removed: 8/19/08
Next appt.: 11/18/08
my overjet and crossbite have both been resolved through Surgically assisted rapid palet expansion and the expander,,the change is Amazing!!..ssfw..I hope the expander works wonders for you too!
crowding, mild overjet, and crossbite
SARPE AND R.P Expander: 7-14-05
extraction : 9-15-05
Brace date: 9-29-05
Expander out! 1-12-06!!!!! after 6 long mos.
Taking them off!!! Feb 26, 2007
http://www.archwired.com/phpbb2/viewtopic.php?t=5209
Brace date: 9-29-05
I had extractions and elastics.ssfw wrote:I was wondering how your orthodontist is reducing/correcting your overjet? I have an overjet and will be getting braces in a few months to reduce the overjet.
Thanks.
ssfw
Bono
Bono
Same here!naomi wrote:I had extractions and elastics.ssfw wrote:I was wondering how your orthodontist is reducing/correcting your overjet? I have an overjet and will be getting braces in a few months to reduce the overjet.
Thanks.
ssfw
Braced: 9/23/05
Duration: 2 years
Duration: 2 years
Naomi, how long did it take you to make the leap from 10mm to 4mm?naomi wrote:I guess I have the record here!!! I started out with an 11mm overjet but the last time the orthodontist measured it was down to just 4mm !!!:jump:
That is excellent!! Sooo encouraging!!
Braced: 9/23/05
Duration: 2 years
Duration: 2 years
It took about a year and a half to get my overjet down to 4mm. However, I didn't have extractions done until over 6 months into treatment. If I'd had the extractions done at the beginning of my treatment my overjet may have been reduced even sooner.seeminglyshy wrote:Naomi, how long did it take you to make the leap from 10mm to 4mm?naomi wrote:I guess I have the record here!!! I started out with an 11mm overjet but the last time the orthodontist measured it was down to just 4mm !!!:jump:
Bono
Bono
Bono
Bono
