What to expect?
What to expect?
So tomorrow at 5pm i am scheduled for my very FIRST adjustment. Anyone care to share what i should be expecting? Just so i can brace myself.
- SilverGirl
Re: What to expect?
Hi, there!
I seem to remember that on my first adjustment it was a little sore when they removed the ligs (but not too bad - they just have to press a little on tender teeth) - and when they took the wire out it felt BIZARRE! I didn't realize how used to the pressure I'd become, and it really felt like my teeth were splaying out! (Which of course they weren't.) Putting in the next wire wasn't bad, but then it got pretty tender again when they put new ligs on due to the tugging - but it didn't last long at all. I don't really remember feeling sore until a couple hours afterward, and then I was on Advil for a couple days at the most. But it was NOTHING like the soreness I had when I first got them on. And each adjustment after that has been easier and easier.
- BraceFace2o1o
Re: What to expect?
I go for my 1st adjustment on Monday and although I had a feeling that when the Ortho changes the ligs it might feel a bit funky, I don't really know exactly what to expect.
I like what you did there!Plumcore wrote:Just so i can brace myself.
Thank you SilverGirl, that is just what I wanted to readSilverGirl wrote:And each adjustment after that has been easier and easier.
Re: What to expect?
you might be a little sore but not everyone will be, the hardest part for me was just getting adjusted to having braces in the first place
Re: What to expect?
If you are getting a wire change your teeth may feel sore afterwards for a couple of days, but if you are just getting your ligs changed it shouldn't be too bad
Re: What to expect?
The first ajustment was nothing as the starter wires were so light. The new wires caused some soreness for a couple of days, not a big deal, but then the following week things started feeling really loose and strange! It was nice having already read on here about bites coming apart before getting put back together again, otherwise it would have been a lot more troubling. Third set of wires has gotten things moving even more.
It cracks me up at how much of a gearhead my orthodontist is, in his own way... he would fit right in with my moto riding/wrenching buddies. When he boasts of the performance of a wire, bracket, etc. he could be any of us talking up an new exhaust or suspension kit.
Re: What to expect?
AND I AM BACK, wires were changed, molar bands put in, elastics changed (pale green now) and i got 2 new wire twists. Also the ortho said i did amazing progress in just over 2 weeks, and the lowers may be placed as early as feb.
